Phone idle seems to be using a lot of power and battery draining really fast any suggestions, restarted phone no joy cheers
You can check in Settings > Battery > Show battery usage see what apps are using the most power.
@Rainking37
The main battery usage should be Screen, followed by Android and standby/idle.
Hi @Mwoolley72, welcome to the community. I am sorry to hear about this.
Do you have the same issue in safe mode?
Didn't know there was a safe mode so no not a clue cheers
After i update my xperia x to 7.1.1 i've experinced over heating and battery drain... 😞 call history lag too...
It's a big shame for a company like sony...
Hi @Roozbeh_R, welcome to the community. I am sorry to hear you're having touble too
Have you tried the step I mentioned earlier? Testing it in safe mode?
Cheers Cameron there was a noticeable improvement in battery in safe mode cheers just finding out which is causing it, possible Google fit as it measures your steps not 100%
I have had this issue for a while on and off. Phone gets hot too. Usually its screen, phone idle and Google play services that are the main battery drain. Tryong safe mode for a bit to see if that helps. Will do a day tomorrow of normal use, or as normal as safe mode will allow, and report back.
@Rainking37
Here's what my battery showing
Hope this helps
