Is it normal for a battery to drain so quickly when the issue is the screen. I have turned the brightness right down and the screen time out to lowest time. After 20 minutes on Google and a couple of apps, it had lost 20 % which seems a lot??
Hello and thank you for trying to help me out here... 😃
I will first tell you about ALL problems Ive had with this device since I got it some weeks ago:
1. Battery discharing fast. Worth to notice is that in the morning, when I unplug the power - the battery percentage drops a few percent just the first half an hour, almost directly or when doing "light stuff" with the phone.
2. The peformance of the phones feels from time to time very, very low: Menu lags, scrolling lags et.
3. The phone becomes very hot occationaly, even though its no heavy apps running at allt (like something its going on in the background).
4. The sound seem to bug from time to time. I first noticed this when using Sony Audio recorder. The recorded sound had some disturbance, static. After safe boot this dissapeared. But from time to time, I stil hear some weird static noice, very shortly - bit still...
5. The screen seem to (quite often) miss when i swipe or toutches the phone. Sometimes I have to try as many as 5 times before the phone seem to react. (no gloves etc).
6. The camera seem to be unresponsive. Sometimes when I turn it on, it only shows "what it sees" but now GUI at all, no buttons, not sliders etc. Also, sometimes it wont take a phone when I press on the screen (the physical buttons seems fine though). Could have to do with nr 5 above.
I have tried both Fail Safe Mode, and I have also factory resetted the phone. The problems remains.
Im not sure what more I can do. Im not even sure if the drainage is normal, or if it has something to do with the other problems. What I DO know is that Andoid 9 / Pie seem to got autoinstalled while I set up the phone the first time. Could these problem have to do with latest android?
There are some settings, from the suggestions you gave me, that I can't find in Android 9. Wifi-scanning is one of them. It turned on when I choosed that I wanted my wifi to turn on when I got back home. ("...Then you need to activate wifi-scanning...something...something..."). But there is only a way to turn of the feature to start up wifi, not to shut down wifi-scanning. Is this gone in 9 / Pie?
How about the other settings, are they applayable to 9 / pie?
Do you have any more suggestions for me? Whats up with my phone?
Thanks in advance!!
The best option then is Xperia Companion.
Read the post carefully and go.
Share your experiences with us.
Thank you.
Before I do that I will post all my problams in the main XZ2 Compact section here in the forum.
My new thread in XZ2 Compact section.
I cant be the only one with these problems. Another problem was just added too:
The front camera shutter and flash (white screen) does not to be in sync. Images gets dark.
