Hi.
I have a problem since 8.0 update on my Xperia X Compact. Since the update Xperia's Backup and restore doesn't work. I have automatic backup turned on but it appears that every week it just skips it. After trying to do it manually app crashes (I get error message: Backup and restor has stoped working).
I tried:
- restarting the phone
- restarting in safe mode
- use sd card for backup location
- use Google account for backup location
- backing up separately (only apps, home screen...)
It always displays same error message and app restarts after it.
Thank you.
After this it started and stayed at 0% for couple of seconds than it crashed again (Backup & restore keeps stopping).
Edit: It appears that Xperia Home layout causes the crash. After unchecking it backup worked.
Settings > storage > other apps > menu > show system apps > Backup & restore > clear data > restart your phone > try again
but still crash on any restore attempts, or auto-backup, or file change attempt.
