x
daanish_chawala
Visitor
AT&T LTE
Hi all,
I just got the X Performance dual sim (F8132) and I've been having some trouble getting LTE service on AT&T.  I tried every combination of APN settings I could find on the net as well as using the downlaoded internet settings that the phone can pick up by itself.  I called 611 to make sure the IMEI number matched--still no luck.  Has anyone else been having any issues?
1 ACCEPTED SOLUTION
Accepted Solutions
daanish_chawala
Visitor
Thanks all for your input, problem solved! This may be useful for anyone else trying to connect their X Performance dual sim to AT&T LTE. Turns out that AT&T blocks LTE to Sony IMEIs. The problem was solved by putting in an IMEI on my account from a random phone they had in store. No changes were made to the APN settings automatically downloaded by the phone. Hope this helps anyone else having trouble and thank you guys again for your assistance
10 REPLIES 10
CameronT
Champion
Hi @daanish.chawala,
Can you double check you have LTE as your preferred network type? You can do this under Settings > More > Mobile Networks > Preferred Network Type.
profile.country.GB.title
Uliwooly
Expert
Are you 100% sure that AT&T has the IMEI number, also how old is the SIM card?
daanish_chawala
Visitor
Hi @CameronT
yes, LTE is set as preferred
@uliwooly, I called once to update it and when I called again, they said it was showing a Samsung IMEI and that they updated it. It's possible they might have still screwed up in updating it the second time. SIM card is brand new
CameronT
Champion
@daanish.chawala,
Is it connecting via 3G?
daanish_chawala
Visitor
Yes, I am getting H and H+ indicators at the top
CameronT
Champion
@daanish.chawala,
I have a feeling that the issue may be on AT&T's side in that case. You would normally get LTE in your current location yeah?
daanish_chawala
Visitor
Yeah, I'm in NYC. I plan to go to AT&T and get a new SIM but after that I'm out of ideas
CameronT
Champion
@daanish.chawala,
Good luck, please let us know how you get on.
daanish_chawala
Visitor
