Hello again!
I just installed the Arrow Launcher in an Xperia X with the latest software installed and I had no troubles uninstalling it.
What I did was that I went into Settings > Lock screen & Security > Device administrators > tapped on "Arrow launcher" (the checkbox next to it was not marked) and in the bottom of the next screen there was an option called "Uninstall" and the app/launcher was uninstalled.
If you go back to Settings > Lock screen & Security and tap on "Clear credentials", try uninstalling the launcher again.
Let me know how it goes!
You're welcome!
Let me know if there is anything else I can help you with and have a great day!
