x
Accelerometer stops working
SOLVED
Mikvandorp
Visitor
The accelerometer of my x performance stops after some days so auto-rotate and other stuff does not work anymore until I reboot...
Tags (1)
410 REPLIES 410
PimN
Visitor
Netflix and Snapchat just had an update, 1 hour ago I did a reboot so I will wait what happened next. Keep you updated
Bufferunderrun_
Visitor
Same problem here. Accelerometer stops working constantly. Reboot is only a temporary fix. Reset doesn't help. Oh! And my camera overheats.
Disappointing phone. Never Sony again.
KMH1
Visitor
It's the same problem after netflix and snapchat update.:-(
PimN
Visitor
Unfortunately It stops again.
TsengHan
Visitor
Started to have the same issue several days ago... Please fix it
Juju1981
Visitor
I Also have same on Xparia X performances. Accelerometer and Gyroscope stops couple of minutes after reboot. Multiple reboot done already, and nothing solve the issue. All soft are up to date.
Kindly request Sony to work on that issue as it seems that high qty of users are experiencing the problem.
Thanks to keep user updated.
Best Regards
Juju1981
Visitor
As per Xperia support center chat done today the phone needs to be shipped to repair center in this case.
Can someone at Sony confirm if a soft update have a chance to fix the problem or we all users experiencing this issue should contact local repair center for phone exchange ?
A quick feedback will be highly appreciated.
profile.country.DE.title
webwude
Member
It might be very wrong but...
I had this issue once a few days ago. Meanwhile I installed thouse maintenance updates and disabled a bunch of system apps (e.g. ar-effect, lifelog, etc). This was about 5 days ago. I did NOT reboot the last four days and took quite a lot pictures - so far the gyroscope and accelerator still works.
It could post a list of my disabled apps - maybe this is at least a workaround - or I am just lucky for now? I don't know.
Juju1981
Visitor
Interesting. Yes a list a disabled apps would be a appreciated. I also that lifelog is in the list. A high ranking "suspect" as it use the accelerometer continuously to be able to work as a pedometer.
Vikont
Visitor
in my phone lifelog was disabled more than one month ago, so it is not a reason I think
