The accelerometer of my x performance stops after some days so auto-rotate and other stuff does not work anymore until I reboot...
If you read earlier in this thread, someone said a solution does not include disablling some other feature. (11/11/16 Edit - the location history only records where you have been, as opposed to location services which is used by apps like Pokemon Go & Chrome & Maps to help you navigate places some more info can be found in an article by Alex Dobie at Android Central)
An app bundled with the phone should not create this kind of problem.
I have noticed many of the photos taken the phone upside down, or incorrectly oriented, can another camera app use the hardware on this device?
This is really becoming a problem for me. So many reasons I need to switch orientations throughout the day and it doesn't work at all. I spent a lot of money on my X-performance, and this is not acceptable.
Hi, I tried to use others camera apps, but the results are the same.
