The accelerometer of my x performance stops after some days so auto-rotate and other stuff does not work anymore until I reboot...
Same problem here in israel with XP
Accelerometer sensor will stops working in sometime after I put it in my pocket and move like walking, driving a car or riding a bike to other place and it will return to working again after reboot.
Model F8132 Firmware v.35.0.A.1.275 Thailand
I just deleted a game I had installed and now the auto rotate seems to be working fine, I'll see how it goes, also I stopped Google now like a previous post suggested as I don't think I started Google now whilst everything was fine. I've had the phone for 3 months and it's all worked fine until last wk when I had an update. Let's just see how it goes
The best was to stop Google now is settings, apps, Google app, storage, manage space, clear all data and Google search data. But then not to open Google app, or if you do then don't agree to Google now. Needs a fix for this though. We should be able to use Google now
