The accelerometer of my x performance stops after some days so auto-rotate and other stuff does not work anymore until I reboot...
Same problem here in Thailand, Sony Thailand said I'm the first who face this problem with X Performance model bring the phone to service center (After try many solution by myself).
Tuesday was my 2nd Time to go to Sony Thailand service center and they asked me to left the phone to investigate ~1 month, worst case they will change me a new mainboard. I'm waiting Sony Thailand for workabale solution for this problem.
BTW, camera not good as it shoud be, I even cannot scan 2D barcode from X Performance.
Sony should say something, it seems we are encountering same issue all over the world.
I think it maybe relate with "What's New" app.
My list of disabled apps
- AR-Effect
- AVG Protection
- Lifelog
- Movie Creator
- PlayStation App
- Lounge
- Spotify
- TrackID
- Video & TV SideView
What's New cannot be disable, so I just forced stop it.
When What's New was stop, I don't have the issue, but it will come back automaticlly after reboot.
When What's New is on working, the issue will appear.
I found the way to disable What's New : http://www.askmeaboutlinux.com/?p=3069
And I don't have this issue after I disable What's New, I will keep watching it.
I still have the problem
I hope Sony will find the cause and fix it.
@webdude
ok, fine ...noticed that you have disabled a lot of apps ...I am wondering whether the Watsnew is influencing the phone in combination with some app in your list (below reported)... (indeed I have disabled whatsapp and since about 3,5 hours everything is fine ...I have many of the apps you have disabled).
In this case, looks quite complicated ...something which is not expected by a telephone that has been paid more than 500 Euro...
This is the list od apps disabled by webdude:
- Amazon Shopping (I am using the original amazon app)
- AR-Effekt
- AVG Protection
- Chrome (since today, due to high cpu usage)
- Facebook (I just the mobile site)
- GMail
- Google App
- Kalendar (Google one - I use Xperia calendar)
- Kobo ebooks
- Lifelog
- Movie Creator
- PlayStation App
- Skizze
- Sky Go
- Spotify
- Sticker-Erzeuger
