The accelerometer of my x performance stops after some days so auto-rotate and other stuff does not work anymore until I reboot...
Boot in >>> safe mode and access the second account, does the camera rotate (while in safe mode)?
Hi @Tysimon1991,
Welcome to the community.
You may experience that the Xperia X Performance has issues with the accelerometer, gyroscope, magnetometer, ambient light, proximity and the barometer. One of the most common signs that the sensor has stopped working is that the screen rotation doesn’t work. As a workaround, try to restart your device.
We are working on a solution. A new software version will be available within November, 2016.
Note! Software rollouts are a phased process – timings & availability may vary by market/carrier.
Tip: If the barometer feature is an important feature to you, it might help to disable the Google Location History as a work around.
