Kamelnageh
Visitor
4G problem
Hi guys, i had apdated my xperia x to nougat but after update i cant recieve 4G/LTE signal on my device.. Can any one help me please?
5 REPLIES 5
YoGem
Leader
@Kamelnageh in all honesty I am facing the same issue but it's intermittent... Seems that there is a very weird handover to 3G if LTE signal is not too strong... Probably a matter of thresholds..
@Emir are you aware of this?
profile.country.PH.title
MarlonUk1
Expert
hi @Kamelnageh
can you try to go to service menu? dial *#*#service#*#* ( the number equivalent on the dialer) and go to service settings >network type 4G only
can it detect 4g signals?
Kamelnageh
Visitor
I solved the problem by remove the sim from socket one to the other one and reset the network setting then i searched for the 4g then my device recieved the signal... After that i got the sim back to socket one and did the same steps and it work too
Kamelnageh
Visitor
Tags (1)
YoGem
Leader
@nolramlb - I tried to connect using LTE only and it does but with AT&T (has a strong LTE signal), not with T-Mobile! (Has a LOW LTE signal, that's why I believe there is something going on related with thresholds...)
@Kamelnageh - Glad you found a solution and that now it's working for you.
