Добрый день.
Решил посмотреть на телевизоре KDL-32WD-756 фильм с DLNA сервера в контейнере MKV
General
Unique ID : 220418872625847314661078170142699187272 (0xA5D3217632E02A56BBEB72CF00146C48)
Complete name : Babylon5_s3e10_Severed.Dreams.mkv
Format : Matroska
Format version : Version 2
File size : 1.00 GiB
Duration : 43mn 44s
Overall bit rate : 3 284 Kbps
Encoded date : UTC 2013-05-04 19:50:22
Writing application : mkvmerge v3.3.0 ('Language') built on Mar 24 2010 14:59:24
Writing library : libebml v0.8.0 + libmatroska v0.9.0
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 43mn 44s
Bit rate : 2 323 Kbps
Nominal bit rate : 2 488 Kbps
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 fps
Original frame rate : 25.000 fps
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.234
Stream size : 727 MiB (71%)
Title : PAL
Writing library : x264 core 129 r2230 1cffe9f
Encoding settings : cabac=1 / ref=5 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=4 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=4 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=2488 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Language : English
Default : No
Forced : No
Audio #1
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Format settings, Endianness : Big
Codec ID : A_AC3
Duration : 43mn 44s
Bit rate mode : Constant
Bit rate : 448 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 140 MiB (14%)
Title : Rus @ 448 kbps
Language : Russian
Default : Yes
Forced : No
Audio #2
Format : AC-3
Codec ID : A_AC3
Duration : 43mn 44s
Bit rate : 448 Kbps
Bit depth : 16 bits
Title : Eng @ 448 kbps
Language : English
Default : No
Forced : No
Text #1
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Title : Rus
Default : No
Forced : No
Text #2
Format : UTF-8
Title : Eng
Default : No
Forced : No
Разрешение в файл 720x576@1024x576, то есть исходник 720x576 должен воспроизводиться как 1024x576.
Видео воспроизводится, но телевизор игнорирует соотношение сторон. И оно воспроизводиться с разерешением 720x576 - вс объекты вытянуты.
До этого смотрел это же файл на телевизоре Samsung UE32F5300AK, такой проблемы не было.
Как исправить соотношение сторон, не конвертируя файлы?
Он воспроизводится как положено, в соответствии с с приведенной вами информацией:
Width : 720 pixels
Height : 576 pixels
Медиапроцессор масштабирует картинку до 1920х1080 и выводит ее в широком формате 16:9.
если бы ТВ воспроизводил нативное разрешение то вы видели бы на экране окно площадью 25% экрана, в котором транслируется видео с вытянутыми пропорциями.
Пираты особо не заморачиваются на технических аспектах изготавляеого ими видео, т.е. не знают технических подробностей.
Если бы избражение масштабировалось с 720x576 до 1920x1080, то проблемы бы не было, то есть до пропорций 16:9, как указано в файле.
Но оно масштабируется до 1350x1080, то есть в пропорциях 5:4, как в разрешении видеопотока для анаморфного видео
А При чем тут пираты? У меня все видео, снятое на Sony HandyCam (2006-го года, miniDV), Canon PowerShot S3, которое я перегонял в DVD сохранялось с разрешением 720x576@768x576 или 720x576@1024x576. И даже сейчас я для тех, кому нужен DVD из FullHD с Canon EOS 600D я перегоняю в 720x576@1024x576. Любой из моих файлов будет воспроизводиться на данном ТВ с неправильным соотношением сторон: 1350x1080 вместо 1920x1080 или 1440x1080 при масштабировании до границ экрана.
Поле "Display Aspect Ratio" есть в спецификации кодэков MPEG2, MPEG4 Part2 (DivX, XviD), MPEG4 Part 10 (AVC, H/264, x264)
Вы утверждаете, что при воспроизведении на ТВ вашего контента, по бокам экрана имеются довольно широкие ветикальные полосы?
Зачем вообще меняете исходное разрещение на обратонаном контенте, с исходным разрешением проблем при воспроизведении нет, да и качества конечному видео это не добавляет.
Вам проще подобрать нужный формат, чем ждать изменений в проигрывателях ТВ.
это ваше утверждение насмешило до слез: - "Что характерно, пираты не нарушают спецификации кодэков и контейнеров".
Да и в качестве примера у вас приведен файл явно скачанный с какой то шары.
Не только полосы, но изображение вытянуто по вертикали (а точнее сжато по горизонтали)
А вот тут лежит видео, которое я хотел посмотреть на ТВ с DLNA-сервера
Затем, что спецификация DVD требует, чтобы видеоконтент не превышал размера 720x576.
Во-первых, у многих еще в ходу DVD-плееры. Во-вторых, старый контент, который был сделан 10 лет назад сейчас переделывать глупо.
Эффективеное разрешение 1024x576 из анаморфного 720x576 даст более высокое качество изображения, чем реальные 720x405, если не использовать анаморфирование. В Вертикальной четкости это будет 1,4 раза. Тем более, что ТВ при ресайзе явно не будет пользоваться алгоритмом Lancoz3
Даже стандарт 1080i интернет вещания предполагает анаморфный 1440x1080 источник, который потомдолжен быть преобразовани в стандартный 1920x1080.
То есть, я должен взять и перекодировать более 500 часов своих записей, явно теряя в качестве на переконвертировании, толдько потому, что аппараты Sony не могут воспроизводить контент, сделанный по спецификации форматов?
По-моему, мне проще будет сдать этот ТВ, как бракованный и купить нормальный, который на 100% следует спецификациям форматов,,если это политика Sony. Если это Ваше личное мнение, то, оно явно нацелено на ухудшение общего отношения к продукции Sony.
Да и в качестве примера у вас приведен файл явно скачанный с какой-то шары.
Для порверки работоспособоности ТВ можно использовать различные источники. И да. Сам файл проходит валидацию на соответсвие форматам MPEG4 Part10, MKV
А для наглядности, в этом сообщении я выложил ссылку на СВОЙ файл, автором и правообладателем которого являюсь Я. Вот его медиаинфо.
$ mediainfo MVI_7893.mkv General Unique ID : 43483501948826185766455900436459727926 (0x20B69E2B5A3CD1270A291FD6A8F8AC36) Complete name : MVI_7893.mkv Format : Matroska Format version : Version 4 / Version 2 File size : 77.2 MiB Duration : 2 min 36 s Overall bit rate : 4 132 kb/s Encoded date : UTC 2017-10-24 01:19:43 Writing application : mkvmerge v9.7.1 ('Pandemonium') 64bit Writing library : libebml v1.3.4 + libmatroska v1.4.5 / Lavf56.40.101 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L3.1 Format settings, CABAC : Yes Format settings, ReFrames : 8 frames Codec ID : V_MPEG4/ISO/AVC Duration : 2 min 36 s Bit rate : 4 000 kb/s Width : 720 pixels Height : 576 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 25.000 FPS Standard : PAL Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.386 Stream size : 74.8 MiB (97%) Writing library : x264 core 148 Encoding settings : cabac=1 / ref=8 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=4 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=5 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=750 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=4000 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00 Language : Russian Default : Yes Forced : No Audio ID : 2 Format : AAC Format/Info : Advanced Audio Codec Format profile : LC Codec ID : A_AAC Duration : 2 min 36 s Bit rate : 128 kb/s Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 kHz Frame rate : 46.875 FPS (1024 spf) Compression mode : Lossy Stream size : 2.39 MiB (3%) Language : Russian Default : Yes Forced : No
Замечательно что Вы аргументируете свои доводы.
Подводя четру, можно сделать вывод: ТВ другого производителя могут тянуть картинку по сторонам до исчезновения черных вертикальных полос, при воспроизведении нестандартного контента, а Сони нет, он воспроизводит по честному, в соотвествии с метаданными файла.
Контент у Вас нестандартный, Вы это сами подтвердили.
Попробуйте все же делать контент стандартизированный, без непонятных преобразований.
В том-то и дело, что это разрешение стандартно для Sony
D-1 resolution is 720 (horizontal) × 486 (vertical) for NTSC systems and 720 × 576 for PAL systems; these resolutions come from Rec. 601.
И стандартно не только для Sony, но и для всей телеиндустрии.
В метаданных файла (а точнее кодека) есть поле "Display Aspect Ratio". Это поле мало того, что сответсвует спецификации MPEG, так еще и стандартно для всей видеоиндустрии.
Нестандартный контент, это когда высота кадра не кратна 8, а ширина, не кратна 16. Нестандартный контент, это видео в формате x264 в контейнере AVI. Нестандартный контент, это каогда видеопоток в контейнере x264 имеет более 16 опорных кадров. Нестандартный контент, это когда в аудиопотоке AAC нет заголовка (И тут Sony поражает - это единственный аппартные плеер, который не сругался на дорожку и ее воспроизвел). И могу привести еще кучу примеров.
Даже многие бытовые плееры, такой изврат воспроизводят.
Все что есть в спецификации формата, в частности ISO/IEC 14496-10:2005/Cor1:2005 , не может быть нестандартным.
Все строго по стандарту MPEG4 Part 10/
Иначе, это не доводы, а балабольство или троллинг.
Салют!
А в других если контейнерах (mp4, AVI), то фильм так же с искажениями воспроизводится?
MPEG2 в AVI таже картина.
MP4 не пробовал еще.
