cancel
Showing results for
Search instead for
Did you mean:
Tekst ingeven op mijn afstandsbediening
SOLVED
profile.country.nl_NL.title
petnek
Visitor
Hallo Sony Bravia gebruikers,
ik wil bij YOUTUBE een titel intikken (bij ZOEK) met hulp  van mijn afstandsbediening. Hoe kan ik letters intikken?
1 ACCEPTED SOLUTION
Accepted Solutions
petnek
Visitor
ik vond ergens op het forum het volgende, afdoende, en eenvoudige antwoord.
I've recently purchased a KDL-32EX703 TV and I cannot enter text and numbers using the remote control when trying to log on to websites such as Love Film and You Tube. Is there a button I need to press on the remote in order to be able to do this or should I alter the settings?
On YouTube when you what to search for example, simply highlight Search in the menu when it appears and press the OK/Round button, 'New Seach' will appear press OK/Round button again, and 'Search for:' will appear. Again press the OK/Round button and a big key pad will appear on the screen you can then type on you remote control the text as you would on a mobile phone.
Thank you. Problem solved!
1 REPLY 1
petnek
Visitor
