Partagez votre expérience!
Hello,
Is there a plug/adapter allowing the connection of transmitter’s WLA-NS7 optical cable Digital In/Out to S-CENTER optical of TV Bravia XR-55A95L ?
Thank you for advice!
M-Y
@maczarn89 Are you going to connect a 3rd device to them? Do you want to connect the TV via the optical cable? Optical audio output and S-CENTER SPEAKER IN share the same terminal in this Tv model
Hi @SatoruGojo
I need to connect the wireless transmitter WLA-NS7 designed for BRAVIA XR and using Digital In cable (square ends) to my TV BRAVIA XR-55A95L having S-CENTER OUT entry (round).
Thus I need a workaround solution. Could you help me with this, please?
No problem to connect my headphones WH-100XM4 to the transmitter WLA-NS7 using Bluetooth and phone app Sony Sound Connect.
Thanks!
@maczarn89 I don't think there's any adaptor that would allow such connection, but you can connect audio device by Bluetooth to your TV directly as it has A2DP Bluetooth profile.
