Z4 no sound when recording movie.
Bad sound if mic is enabled
are you using the deafult camera app? how about when you use 3rd party apps.
run xperia diagnostics
does this happen when you are on safe mode
Yes I think it was a year ago or so that movie recording with direct sound worked fine..
Then Sony? removed that option and forced mlc use to get sound in the recording.
That's not a pro solution? sound gets really bad.
Right, not the mic option but direct sound option.
That's how it's supposed to work, it's supposed to record YOU talking and/or your surroundings NOT whatever it's on the screen, you could turn up the volume of the videogame or whatever you have running
or
use third party app
@Viridis If I'm not mistaken it has been like that since it was preloaded with Xperias, I don't recall if there was a copyright restriction
>I think it is is strange?
>But it is a screen recorder, not i video camera?
>Screen recorder = record the screen, not the sound?
>I need somthing else if I want to record screen with sound? what?
>just looking at YouTube.
or
use third party app
>same problem with third party app.
>Sony (or Google) removed option to record sound and video a year or so ago.
