I have a Z3 tablet compact Wi-Fi, stock, no root, that is in a boot loop at the black and white Sony logo. Repair using Xperia companion is successful, but the loop continues. I've also tried flashing stock ROM using Flash Tool. Again, no errors encountered but the boot loop continues.
Any thoughts? I've also tried running the battery down to no avail.
Thanks,
Daniel
According to Sony Xperia Z3 Manual to get rid of this issue do as following:
I hope this might fix your issue. For more deatils you can also check manual.
I've had this problem.
I've tried to repair software using Xperia Companion for a few days, unsuccesfully.
I noticed same water condensation on the memory card when i removed it.
I put the device in a warm place with all the cover totaly open for few days, to evaporate internal water condensation.
I've tried to repair software using Xperia Companion, this time succesfully.
Hi to all,
I'm having the same problem. The tablet is stuck in bootloop and unfortunately I cannot even use Xperia Companion cause it seems it needs Transfer Multimedia (MTP) to be accessible.
Moreover, there is a secure pattern mode so anyway I cannot do anything.
Any helps ? besides the "condensation problem", someone has got any solution with this kind of booloop problem ?
Thanks for your help
