Hi all,
My kid recently drop my phone and crack my screen. Luckily the touch screen is still work and all operation in the phone is still working however the screen is still crack. Anyone have tutorial to replace the surface screen but still re use my existing lcd. Attach is the picture of my crack phone and the part I bought to replace.
Hi @TCSS87,
In instances like this when your device has been damaged we do not recommend replacing parts or repairing it yourself as this could likely cause more issues.
I would suggest getting in contact with your Local support so they can arrange the repair for you.
Good luck
