HI, I'm having trouble finding if my tablet z3 is WiFi only or if I can use a sim card in it. There is a sim slot but unsure.
Thanks
Thanks for confirming that
The particular model you have is the Wifi only variant so you will not be able to use a SIM card with this device unfortunately.
Hopefully that helps
Can you confirm the model number of your tablet so I can check this out for you.
Go to settings > about tablet > model
Let me know
HI, thanks. The model number is SGP611.
Thank you
Ah Ok, thank you
Another way to quickly check when viewing eBay listings etc and the seller hasn't included the model number is to check if the box picture has a phone dialer icon.
If the box isn't available there should be a phone dialer icon on the homescreen or the app draw.
There are 3 models
SGP611 (Wifi 16GB)
SGP612 (Wifi 32GB)
SGP621 (Wifi 16GB + LTE)
