Hi.
is there any official solution for change white balance of X Tablet Z in 50% brightness ?
the screen is yellowish.
tnx
IN Persian. And it is very effective solution.
1_ تبلت باید روت باشه
۲_ ریکاوری Teaming باید نصب شده باشه
3_ از xda فایل whitebalance با پسوند zip مربوط به Sony Xperia z/ zl دانلود بشه http://www.4shared.com/zip/xYGFDsMCce/WB_bymw1kaduxx972fixe.html
4_ با teamwin فلش بزنید
مشکل حل میشه
1_ rooted xtz
2_install teamwin recovery
3_download whitebalance.zip from xda/Xperia z/zl
4_ flash it without zip verify in teamwin.
It might be the Sony screenprotector that has a yellow glow.
People have removed it and found the results better.
It's the protection that remains after removing the first protection plastic that's not as flat.
How to: to find on YouTube.
I didn't knew that at the time, so i put another screenprotector on.
Be careful when/if removing, and buy another - not yellowish - protection.
tanks
but before remove the anti-shatter layer , can i use white balance option ( like xperia z) for yellowsih ?
I found the white balance app, but I think it is not a normal app.
It has extra files that give the impression that much more is changed under the hood.
So be sure you know what you are doing before install.
I have 2 screen protectors and no yellow glow.
It's no >8500k but no 6500k either. And less than 40% brightness.
The Sony Z2 tablet has no anti-shatter layer anymore
مشکل حل میشه
1_ rooted xtz
