1st LTE must be enabled with your AT&T account, to do so, you need an LTE phone AT&T branded, so they can input the IMEI number in your account, thus enabling 4G LTE, there isn't a way around it
2nd
APN phone
MMSC: http://mmsc.mobile.att.net
MMS proxy: proxy.mobile.att.net
MMS port: 80
MCC: 310
MNC: 410
Authentication type: None
Bearer: Unspecified
H and H+ should work
Don't forget to give Kudos
Simple because the LTE on that particular Tablet its not compatible with AT&T's
Here is the info
SGP351
UMTS HSPA+ 850 (Band V), 900 (Band VIII), 1700 (Band IV), 1900 (Band II), 2100 (Band I) MHz
GSM GPRS/EDGE 850, 900, 1800, 1900 MHz
LTE Band IV
http://www.sonymobile.com/global-en/products/tablets/xperia-tablet-z/specifications/
Don't forget to give Kudos (Click on the half star + )
AT&T's LTE frequencies
700 MHz Class 17, 1700/2100 MHz
3G and H+ should work
