Hi, really hope someone can help me
My touch screen has just suddenly stopped working, ive tried everything on the support page and still nothing
Reset didnt work either, tried via backup and reset and the little button under the micro SD card flap
Thanks
Hi @MWins, I'm so sorry to hear about that.
Does the device react to touch on any part of the display, or does it not register touches at all? Also, do you experience it permanently or does it occur while you use a specific app or service?
If you look carefully, are you able to find any damage done to the devices display? If not, could you try performing a software repair using Xperia Companion, if you have not already done so?
Let me know how it went!
hi, thanks for the reply
It happens all the time
The only way I can use the tablet is if I connect a mouse, which is useless to me as I use it for gaming
Ive tried repairing the software, reset and factory reset, nothing is working
It did this before and when I connected my mouse then disconnected it the touchscreen worked
Thank you for clarifying!
In that case I am afraid that I recommend you to have your device sent to an authorized service center so that a technician may examine it for you. In order to do so, you may contact your Local support and ask them to assist you as they are well informed in regards to local service routines, warranty terms and consumer laws. ![]()
Hi
My Sony xperia Z4 is not responsive as well (screen broken but LCD is still good) but also I'm having random touches on the tablet without even touching the device
Is there a way I can disable the touch screen and use only the mouse to control the tablet
Thank you,
Gaby
