Hi, just dug out a Capaciyive Stylus that i dont use & tried it on my Z2.......works fine, nice & accurate.....if you do a Search on the Forum some people say a stylus works & some dont.
Do you have Glove Mode enabled on yours :smileysmileywink:
Hi folks, I have a silly question really, as I am new to Sony, only picked up my new Xperia on Friday and still getting to grips with it. None of my previous stylus appear to work at "all" which seems strange as they are fine on my IPAD 2 and Samsung Note 2 and Note 3? I use a lot of productivity Apps requiring a stylus and my finger will not suffice as I really need precision. I checked out a lot of reviews prior to selecting Sony and none of them mentioned stylus compatibility issues. Appreciate if someone could advise what stylus works with this tablet. Cheers
Hi Kickstand, answered youre earlier post but this section is for the Z2 Mobile.....there is a section for the Z2Tablet.....either post new question there or one of the Mods will move your posts once they notice.
More chance of your question being answered, good luck :smileysmileywink:
Thanks a bunch, tried to recreate in the tablet section to no avail, here is hoping Mod can assist me.
Thanks again.
Threads merged - Do you have a Z2 or Z2 tablet so I can move this to the correct section
Glove mode is found in Settings then Accessibility
Hi Thommo...he has the Z2 TABLET
Cheers and moved
