I was sending out an email when my Xperia Tablet Z screen starts to flicker and it restarted itself. When it was back on, half of the screen is not working anymore whilst another half of the screen works perfectly fine and responding to touch/clicks onscreen. Auto-rotate works as well. I have tried rebooting and resetting to factory setting but the same issue with the "half-screen" persists.
I did not drop or mishandled the device since I purchased. I hope it is still under warranty as it has not been a year of using it.
Please HELP!! I need this device for my work and business meetings without it I'm "handicapped". Appreciate any of your expert advice and SONY's feedback urgently.
Thank you.
Hello
Have you found a solution to this problem as I also have the same problem with my tablet.
Hi all
This is definately a hardware problem rather than anything an update etc could fix.
I'm sorry to say its time to either get them sorted under warranty or possibly pay if the warranty has expired
Hi, i know it was long time ago but i have same problem and this is only picture and problem like mine, with Sony Tablet Xperia Z?
Have you fixed and what have you done?
HEllo!
I have the same problem, but I'm out of warranty .... Who advise what needs to be fixed? The servis dealer told me: EXCHANGE SWAP ... but do not want to. Repair will cost € 480. I'll buy a new tablet, better for my, but Sony offered nothing !!!
and you know what caused you a problem?
