Hey guys I was in the middle of updating from ICS to Jelly Bean. So after it was completed it turned off and I tried rebooting it. Next thing you know the sony logo shows but its stuck at that point so I basically can't do anything.
Luckilly I can get into the recovery menu so all is not lost. I tried flashing the zip of the official Jelly bean update but no luck I get a weird error message. : ( .
the error message is in the attachment shown.
Please help
Cmon someone help me pleasee
I need my tablet back!
power button + volume up till see boot screen.
after that recovery screen should pop up do factory reset and see if that fixes problem, otherwise rma.
was tablet charged properly when you did update and plugged in to charger ?
Doing a factory reset doesn't work.
I have no idea how it messed up like this yes I did have the charger in with more than 30% battery.
I have posted a pic of the error above when flashing an official zip.
I've tried everything nothing works I think only a Sony member will be able to help me now .
