Hello
i have a a Sony xperia Z3 Compact Tablet and i have used the xperia companion to repair the software.
i will give you a bakground to the softwarte problem.
my tablet will turn and will go 1 which show the sony xperia then screen 2 which says powered by andriod after the sony livery comes up. and the tablet shuts down. PLEASE HELP
i have used the xperia companion to repair the software but the same problem as before.
Any advice and help will be muched appricated.
regards
Hi @abdul128
Welcome to the community!
Sorry to hear about this
If you have attempted a software repair and are still experiencing issues you would be best to get in contact with Local support so they can assist from here. It is likely the tablet would need to be assessed and repaired and your local support should be able to help facilitate this.
Good luck
