Hi All!
I purchased a Sony Tablet in November at the Sony shop in Singapore airport T3 . Hadn't had any problems with it until I was enroute to Australia the other day.
The battery was starting to go flat, so plugged it in, no charge or power. The power adapter appears ok and the little green light on it is illuminating but no charge or power to tablet.
Any clues or tricks I can try?
Cheers,
Matt
Have you resolved the problem? I am having the same issue and service support are being less than helpful?!
Hi allawee,
I doubt the problem is related to yours because the post above by Mattfopp from March 2012 refers to a tablet not a Vaio..:smileywink:
