I want to use a wifi camera and link it to my tablet s. I have seen plenty on ebay but dont know which one to go for. Has anyone had experience of this. I want to use it as a baby monitor.
Thanks
I know they can be done the other way. IP Webcam allows you to setup your Android device as a streaming device which can then be viewed on a computer.
In theory, if you did have an IP based webcam which works off your network then in theory it could be done. Just no ideas on what app you would need to look for. IP webcam may also do it.
