I have just got this 2 reviews saying it works i cant get it to.
can eanyone hellp??
I have just tried to coneced to my laptop
driver softwear code(10) need hellp please.
what does not work with it?
-- linking a PC and the Tablet ? - only this working is what they advertize for this cable. If that doesn't work:
- either the cable is faulty.
- or it might also be that your PC is unable to get the Sony Tablet drivers loaded.
is the latter the case? look in the traybar lowerright of your PC.
-- do something else, e.g. with an additional usb-converter, connecting a mouse etc.?
For this you need a OTG cable, which allows the usb-socket to be a hub. I doubt if the cable works.
You want a USB cable that has male micro-usbA/B on one side, and female normal usb on the other side.
thanks breedbenR
my bag computer has seen it and as you said cant load sony tablet drivers.
can you hellp please.
getting code 10
