Had Sony S tablet for Christmas and diasapointed that the USB cover does not go back in its place it looks like it is a flimsy cliip that does not work?
Anyone else have this problem?
Or a solution?
Message was edited by: creynish
Returned mine as it would not close replaced with no issues all fine now!
hi creynish, the cover should clip back in place. a gentle push back and there should be a click.
mike.
Nope just does not stay in.
Looks like a return so next question will be how to do that i guess.
Hi creynish,
As mike has suggested, this is not normal.
Have a look at the following link for contact details.
http://www.sony.co.uk/support/en/contacts/tablet
Rich
