I have a Xperia Z tablet.
I was updating it today and the update process was interrupted. Now it shows me the Sony screen and switches off. What can I do? Please help its urgent and i have half a semesters worth of university work on there:smileycry:
Hold down the ON/OFF button + volume up for 10 seconds and your Tablet Z should power OFF. Do this without having the device connected to a power source.
When your device is OFF, download and install Update Service to your PC and then perform a software repair:
www.sonymobile.com/global-en/tools/update-service/
It's downloading now. Will this method retain or delete all the data i have saved on it?
Unfortunately this will delete your data. Since you cannot power up your device correctly you are unable to backup your personal data.
I did what you told me to. My Xperia is now working perfectly and theres an option to keep my personal data which worked perfectly.
Thank you so much for your assistance!
You are welcome, glad to hear that it solved your problem!
While i was trying to update my xperia Z to the latest version there was an interruption. i have done the above suggested solution you gave but still no head way. When i do it, the sony icon will come up then a message notifying me of update failure and that i connect the phone to the system and try again
