just wondering when i transfer music via sd card it goes to the app sony music but theres another music app and i would like my music to go in there but it dosent, anyone know why or how can i get my music to transfer to this app thanks
I think its the app that is the problem. The music doesnt go to the app, the app should read the location of the music.
So you need to see where your music app is looking. Does your app have a scan option? Are you putting music on the internal SD card or your own external SD card
there is two pre installed apps for music the sony one and the one with the earphones just says music ,i transfer music from my external sd to the tablet but in goes into the sony one and not the other but i want it to go into the other one hope that clears it up
