I'm having touch screen problems. For me the tablet randomly doesn't recognize touches during the below instances. In all cases either going to the home screen and relaunching the app or turning the screen off/on will solve the problem. The problems occur several times per day but not constantly.
While not a bug per se, but the android-buttons seem very picky that you have to hit them right on the spot to work.
I have SCR12 official stand too and can't tell that it is worse with it.
Generally touch is more or less reliable but it is far from the experience on Z1 or Z1 Compact. And those double letters are very annoing.
I am in the process of sending my z2 back to amazong for a replacement, due to bad touch issues, but im just wondering if anyone eolse has had theirs replaced and was your new one fine (without touch issues)
When i got my other one, i restored my google account / apps straight away and when they finished i upgraded the fw to .402 straight away, but then still had issues.
I'm just wondering can i leave connecting straight away to my google account, and update the fw, then connect to my google account then restore the z2? i dunno why, im just wondering if this may have helped, or do you think it wouldn't make any difference?
I did do a factory reset of my tablet anyway and this didn't help me.
Thanks
James
Could you please send me your details in a PM, and I will forward this.
Make a relevant topic and include the following.
Name:
Phone nr:
E-mail:
Country:
Operator:
Product:
IMEI nr or IDID nr:
Build number:
Hi all,
Just got this tablet and immediately noticed that the screen isn't perfectly flat. If you lay it face down on a flat surface you will see why. Therefore, that the reason might have a substantial cause contributing to this issue.
If my assumption in the above post is not correct, perhaps, it is the display technology flawed the touch response.
Interesting test on this tablet showing the randomized flaw of the touchscreen.
Mine especially has problems with two-finger multitouch, it's often randomly losing track of either finger while sliding with two fingers (affecting functions such as pinch zooming). Oddly it doesn't show any noticable problems with 1 finger or 3+ fingers.
I have noticed that the touch screen precision/sensitivy issues depends on the surface on which the tablet is resting.
For example:
There are no problems when the tablet lays on a glass table, regardless of using or not using style cover.
When the tablet is laying on an acrylic surface, the multitouch performance is just plain bad, also regardless of using or not using style cover.
When the tablet is in the style cover, and the cover is being used as a stand, the multitouch precision shows issues, but not as bad as when flat on the acrylic surface.
