Hi, I was just wondering if there was a way to 'throw' media to any non-sony device?
In theory, provided your device is DLNA compliant it should work. Whether Sony or not shouldn't matter
Any DLNA certified TV will be able to receive media thrown from your tablet. The difficulty that you may be experiencing is file type. All DLNA devices are bound to support certain file types. From memory I think that this is .jpg, .mp3 and .mpeg2. If you are trying to throw something that is not one of these files it probably wont work. Some manufacturers support other file types but its a bit hit and miss. I woul suggest checking your TV manual to see what it will support. You can always download a file converter as a last resort.
