How about if you remove the updates for chrome?And did you try another browser?
Try to force stop and clear data for the browser.
Which browser are you using?
alexdon - thankyou for this.
Just done this, but unfortunately no change...
uliwooly - the chrome browser.
alexdon - thankyou, it worked....
You are welcome.
