Hi detickl,
Try the following..
Press and hold the power button for about 10 seconds to force it to shut down.
If that does not work then try pressing the reset button. Insert a pin or other slim object into the reset button (hole). hopefully this should allow to force your tablet device to shut down..
Hi detickl,
Try the following..
