Gents,
there is a problem to establish VPN connections:
E/VpnJni (162): Cannot allocate TUN: Bad file number.
It is apparently a known issue: http://code.google.com/p/android/issues/detail?id=21030
The CONFIG_TUN is not set, so it is not possible to create a VPN interface (some VPN functions, included into the default Google ICS code were dropped).
In order to use my mobile via Bluetooth it is a quite necessary functionality.
I would be utmost grateful if you could comment and/or provide a workaround or proper firmware update sorting this issue out!
Thanks a lot & best regards!
Great post. Thanks for sharing. Everyone should be aware of this.
