I'm sorry to hear about your issue, but what if you leave the tablet connected to a wall charger for 3 or more hours ?
Hi exactly the same thing happened to mine there is absolutely nothing you can do it is positively dead. Mine was still under guaranteed although I did have to pay the postage they completely changed the mother board just shows what a pile of crap they actually are would never buy another one there customer service was also bad.
My Xperia Z2 tablet stopped charging too. It happened when the battery was completely flat and so the tablet was switched off. I could not recharge the tablet (the red light would not come on).
I tried different cables, etc. No change. The problem was the charger. Sony, in its wisdom, has made the Xperia Z2 with a slow-charge battery. Continued use with a normal charger (these days most chargers are 1000 or 1500mA) causes the problem. It seems that these higher 'mA' chargers will work when you are topping up the power but not when the battery is completely flat. I was using a new charger (from my new Sony mobile) which is a 1500mA charger, and the red charging light would go off.
I changed the charger to a Sony 850mA charger (i.e. same charger that came with the tablet) and it now charges without fault, albeit slower.
