After updating to 6.0.1 marshmallow a few weeks ago, now I get an error saying systemui has stopped working and have to reboot the tablet. This happens at least once a day.
I have obtained a crash report.
Others have claimed that it was due to an SD card but I removed that same it still happens.
Is there a bug in the marshmallow update and if so when will it be fixed?
Who wants to see my crash report?
Hello @Paulpaul1308,
Welcome to the community!
Sorry to hear that.
When are you receiving this error message? Is it when performing a specific action? For example, when starting a specific app. Is there any change if you boot you tablet without a SIM and/or SD-card inserted?
Are you able to re-create this behaviour if you reboot your device to safe mode? If so, I would advise that you continue with @nolramlb's suggestion and perform a software repair using Xperia Companion. Note that this will reset your device and you should make a backup using Xperia Companion first.
If you perform a software repair, please check if you still experience this behaviour without restoring any data at first.
Let me know how it goes!
At completely random times.
No.
No. I had an SD card present so I removed it, but the error persists.
I'll try out your suggestions later and let you know.
I took a bug report BTW, do you not want to see that? If not, can you tell me why?
Thanks for a swift reply and for the update! I don't think I need to see a bug report just yet, I would recommend you perform the repair first and if this is still happening after that let me know.
Keep me in the loop!
After using Xperia Companion to create a backup, I tried repair twice. Each time it failed:
Please try again later and contact Sony support if the error persists.
Error code: UELoginUnexpectedExit
Code_0
What does that error code mean when trying to do the repair, Google doesn't help:
"Error code: UELoginUnexpectedExit
Code_0"
Why has the support on this gone quiet? I'm not breaking any rules - I haven't rooted the tablet and my bootloader is locked, so why aren't I receiving any support?
I have noticed that systemui tends to crash when I receive a notification. I have also noticed that if something I had running - like a file copy, for example - completes and outputs a notification, then the system sorts itself out and I don't have to reboot. I tried using a different app (sending a message to the tablet through Join) to force a notification the last time it happened but that didn't work, unfortunately.
Like I say, I have captured a bug report.
Sorry for a late reply.
Regarding the error message you are receiving, is there any change if you reboot your computer and try performing the repair again in a few minutes? If possible, try using another computer.
As it looks right now I don't think a bug report is necessary, I would advise to complete the repair first. Let me know if the above helped!
