Hi again
Does anyone know,if or when a good keyboard for the Xperia z will be available please?
many thanks Steve
Well you can use any wired or wireless bluetooth keyboard with it
Well, I think a wired keyboard would need an USB OTG adapter, which doesn't seem nice. I picked up a cheap Bluetooth keyboard at Currys which works fine, it was £19.99. Going to get a bluetooth mouse to see if it works.
