Disaster! Any way of overriding to back into main mode - preferably without losing everything?
HI 1edpsy, as the password is there to prevent others form accessing your tablet the only solution to your problem would be to reset your tablet.
How do I reset my tablet its a soney Xperia z1
HI there
Do these instructions help :
(Taken from : http://www.android.gs/hard-reset-xperia-z1/ )
I cannot get in my tablet its asking for my password which I cannot remember also I donot see a reset button I remove the SIM card slot and there no red button there. I need some help
Hi there
I think it might be best if I point you towards the dedicated xperia forums instead. They should be able to assist you
Oh, ooops - yes mobile phone.
Tablet:
Thanks Nobody-In-Particular : must read question more carefully
LOL
Yes unfortunately this will erase all data on the tablet (unless you have your photos, movies and music stored on an sd card in the tablet - in which case take that out before the reset too!)
