- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
I have installed Spotify premium on my Sony Tablet. It does not work well. It continously says I am off-line. well I am on-line. all other s/w works fine with the net. Any suggestions, solutions?
Espen
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Yes, have you got any playlists that are "available offline"? As a test, make sure none of them are available offline and try playing if you have not done so already.
I ran a playlist side by side on my computer last night and both units had online playlists which were playing at the same time and they both tripped to offline mode for a split second and came back.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Espen. Welcome to the Sony forums
I have not encountered this yet. I will check again tonight but are any of your playlists set to offline? When a certain playlist is offline, it does for some reason keep the notification there.
I will run a more in depth test with my account tonight.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Do you mean "available offline?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
When I installed Spotify on the Tablet, all playlist were available offline by default. I have now made all playlist unavailable on the Tablet. It seems to work fine.
To check, I made one list available offline. It did not make Spotify go offline. There is a bug here, but it seems we can navigate pass it.
Thanks for your assistance.
Espen
