Hi!
Bought a 32gb Xperia Tablet S last Monday and am happy with it. I have this issue at the moment and would appreciate any advice.
If I do not use the tablet for a time, it goes into a 'standby mode' and I can touch the power switch to wake it up. I then slide the unlock icon to make all active again.
However, after a period of non-use, my tablet switches off completely and I have to reboot and can see the SONY screen and then XPERIA screen, before it boots and is ready to use.
Occasionally this reboot happens within 5 minutes of being in sleep mode.:smileycry:
In Settings -> Display, I have set the Power save mode as checked, and Sleep is after 2 minutes. Also in Settings, Developers options, stay awake is checked but I know this relates to when the tablet is being charged
Please can you advise me if there is any settings that I need to change or if I have been unlucky and have a faulty tablet and will need to return it to the Sony Store!
I was told that the tablet has an 'Eco Mode' but that does not make sense because powering off means no mail check etc etc!
Ofiaich
Hi guys!
Any news for this device??? i think im going to order in the usa store or wait for the new one. i havent seen any problem from usa user...
Message was edited by: tuantung7c7.
over at this site https://www.facebook.com/SonyXperiaTablet and American has reported problems with his tablet...
fee.666
Hi, just a quick comment and observation.
I'm also suffering from this complete shutdown problem when the tablet is in sleep mode. Time in sleep mode before it shuts down and does a reboot when you turn it on is quite random, but it's happening a lot, maybe 10 or more times a day if I'm using the tablet a lot. I've tried all the fixes improvements mentioned in the posts, but nothing works.
The one thing I have noticed which does stop it rebooting when I switch it on is leaving it on charge.
Not sure if this is relevent or not.
I do hope Sony fix it soon though as it's very very anoying to say the least.
I think my problem may be different, Tablet doesn't get chance to go into sleep mode, 15 seconds after start up the screen locks and a reboot starts.
Assuming the sleep mode and wifi issue are linked try this long shot for a fix;
I had an issue with an ultrabook that kept dropping wifi on wakeup and had to go through a reboot to reconnect. I changed the wireless channel to 4 or 6 but not 11 and ping it worked. A WiFi lock app might be worth a try,
What ever the solution is we're ahead of Sony who in their wisdom thought a bit of foam and a free screen wipe would fix my problem!!
is this xperia tablet suitable with the 64gb sd card?. or u guys know where can i buy the sd card good price
Good news with the tablet powering off. Last Monday I sent my tablet off to get the splashproofing fixed and when it returned on Friday I updated to release 6b and since I have had no issues with the powering off.
Steve
yes stbromf31
thank u bro
My tablet shutdown for no reason also, Altough it dont happen when resuming sleep.
It happends when playing a video from web browser.
First i see some glitchy video like it video file did't load correctly then i try to skip thru the video i get a black screen for while.
After that it shutdown it happend 3 times its verry rare but verry anoying.
First i thought it was flash.
Then it happend in chrome without flash also.
I dont think its my tablet just think its a software issue.
I'm running the latest android update.
Message was edited by: Zerokewl
I have same problem. had 1 replaced already because of the recall product....but had this problem also randomly huting down.... I think its causing dead pixel on the screen as I can see one and my fear it may happen more and more pixels to die.....after so many shutdowns no wonder unit may become faulty..... Also this is against saftey if u using as sat nav in car and shuts down and u dont know where u hading and trying to turn it back on.....or if u listen to music it becomes a very loud clichy music which u lose control and shuts down the tablet....i will never trust sony software again....wish I never bought this. thank u sony,,, no wonder u servers were hacked as u are not very keen to build stable software.
Message was edited by: djarben29
When i made topic about it on dutch sony forums topic was just deleted.
Is sony gonna do something against this or they gonna put this whole case in a extinguisher.
Because i don't like it that my tablet shuts down for no reason even if its just once a day usualy only use my tablet for 1 hour a day.
And when i do i want it to work 100% stable no issues.
