Does anyone know where I can get a spare UK charger for the tablet S ?
It seems to be out of stock everywhere and suppliers seem unable to advise if they can get any more stock.
Direct from SONY there is no price, availability information or any way to add it to the shopping basket.
This page
http://www.sony.co.uk/product/sony-tablet-chargers
Only has the Tablet P charger for £29. There seems to be no way to order a tablet S charger.
For a current product this is very poor and a little worrying.. Losing my present charger would make the tablet useless if I cant get a relacement.
Time to eat humble pie. The first call I made to a local Sony Centre had one in stock @£29 ....so the obvious answer i.e. ask a Sony Store - was in fact the correct one.
Hi nickrain and welcome.
Have you tried Amazon?
Or Currys
http://www.currys.co.uk/gbuk/sony-sgpac10v1-cel-s-series-adapter-11350488-pdt.html
Check you get a UK Plug.
Thanks for that. I think I did look at Amazon but the charger seems expensive at nearly £50 with delivery. Currys seem to have no stock at any branch within 100 miles and it's not available for home delivery so you can't order it on line.
Some suppliers offer it at £29 ... but they don't have any stock so I guess that's irrelavant.
I'm really surprised you can't get it direct from SONY
Message was edited by: nickrain
Nick,
Did a quick Google search and this was showing in stock:
http://www.bristolcameras.co.uk/p-sony-sgp-ac10v1-ac-adapter-for-tablet-s.htm
Also some stock at PC World (altough said limited) Very easy to check if you have the currys link just change the currys part to pcworld in the link and keep the rest of the link the same an it will show you stock (the sites use the same backend just different home pages!
http://www.pcworld.co.uk/gbuk/sony-sgpac10v1-cel-s-series-adapter-11350488-pdt.html
Available to collect in store apparently.
Regards
Padster
Thanks for the info.
I orderd it from Bristol cameras and got an immediate email saying it was out of stock. A call to their mail order department inofrmed me that they were unable/ unsure if they would be able to get further stock
I'll persue the Currys/PC world route but so far Curry have none at any local brances and you can't order for home delivery. SONY appear to have no method for placing an order for this item on their on line store
This is really frustrating. I expect SONY to be able to supply a vital accessory for a current model, without fuss, delieverded next day and at a reasonable cost. Not all this Googling around looking for stock at obscure dealers.
I'll try a couple of local SONY shops which seem an obvious route and see what their take is.
