As per title, I've looked everywhere. It should be party of Lollipop but I can't find it anywhere on my device
Hi @daherlihy,
Check this link out. http://support.sonymobile.com/gb/xperiaz3tabletcompact/userguide/Unlocking-your-device-automatically...
Please be aware that the Smart Lock feature may not be available in every market, country or region.
To enable Smart Lock
Hi @daherlihy,
Perfect thanks for this - problem solved
Awesome, glad this worked for you
You can also access the user guide directly from the tablet/phone by going to Settings > Support > Web Support. It will take you to a mobile version of the Sony Xperia support page and you can check the user guide from here.
