has anyone else noticed that when tapping the screen on the top right, there is a slight hollow noise as if there is something lose inside? hopefully it is normal and its a design issue, and not faulty !
Hi
Could you maybe post a photo of what section you are talking about? I have just tried it am cannot find the area which you are talking about. A photo might make it easier but I am sure it is nothing to worry about as not all the space will be filled internal for the unit to function.
