Sandisk has announced the development of a 128Gb micro SD card. Will the Tablet Z be able to make use of this larger card?
The reviews I've read all say it supports up to 64GB.
Rich
it will depend on the filesystem (formatting) of the sdcard. The announced compatibility update to 64 Mb suggest more filesystems to be supported now than for the S-tablets. wait until release and it will quickly be clear.this also matters for opening files larger than 2.3 Gb and so on. (long HD films)
Does the Tablet Z support both SDHC- and SDXC-cards?
The specification page here at Sony only says SDHC, but that isn't right, or is it?
