Hi
I'm using the latest version 32.1.A.1.185 and I have experienced serious performance issues. Especially games Crossy road, Disney crossy road and Shooty skies are lagging and almost unplayable sometimes.
I have done factory reset and the performance is the same. I have no antivirus running.
Tried those games with my Nexus 5X with no issues.
Factory reset it's not the same as repairing the tablet with PCC or Bridge
Don't think that would do it as I just did factory reset.
Reinstall using PC companion seems to have fixed for the most part. Performance at certain points is not optimal but playable at least. Thanks for the tip!
