hi, when inserting my 64gb sdxc into the tablet a message pops up on the task bar saying 'damaged sdcard'. I know its not damaged as the sdcard is new and ive successfully read and written to it using my laptop. is the anything I need to write onto the card for the tablet to read it? Also note that I have no problems with a 32gb sdhc with the tablet ie works fine... any ideas?
spec says max compatible is 32gb sdhc
Did you format it FAT32?
