When using the screen recording, the internal sound (not mic) is not recorded. On the Z3C it records also the game/app generated sounds. Known issue, or can I somehow influence the mixer settings?
Thanks
@backslashhh wrote:
No, I don't. Microphone recording works. Game sound not.
It sounds like the sounds effects of the game application you're trying to record may be protected (copyright). That's probably why you don't get any internal sound effects recorded.
@Johan wrote:
@backslashhh wrote:No, I don't. Microphone recording works. Game sound not.
Simple experiment. Turned on sound on touch. Recorded simple homescreen interaction. No sound recorded.
@backslashhh wrote:When using the screen recording, the internal sound (not mic) is not recorded. On the Z3C it records also the game/app generated sounds. Known issue, or can I somehow influence the mixer settings?
Thanks
Ok, I was wrong. The Z3C has the mic turned on by default. So it seems to record only via the mic. I guess recording directly from the soundcard is disabled because of the mentioned copyright. Consider this "solved". Thanks
Soft ware : fixed you can't on or off internal audio
Hard ware : you can on your head phone with "freezed" mic
This is an excuss not a fix
Answer the question!!!!
#((_@#-_@
