Since I updated yesterday much Xperia tablet Z2 to lollipop the automatic turn on the screen does not work anymore.
Of course this feature used to work two days ago with kitkat.
Is that a known issue?
Thank you in avance for your help help
Fred
Can you boot in safe mode and see if the same occurs?
/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008#U348008
Thanks
You are right. It does not occur in safe mode.
Do I have to try uninstall one by one the latest app?
Ok,
No need to uninstall anything. After booting in safe mode and then in normal mode, autoturn of the screen works properly.
Thank-you for the tip
It might have been a simple glitch. Anytime.
